06-10-21 09:20 PM
07-10-21 07:29 AM
Hi Lorenzo,
Rather than putting the problem description in a word doc, try and describe it in your thread and insert screenshots if needed. In these days of ransomware, not everyone (I for one) is prepared to risk opening documents from the interweb.
Happy coding!
Paul
Sweden
07-10-21 10:23 AM
Hi @PvD_SE,
Thank you for taking your time on this matter.. one more thing I would like to add for the below comment, as per test, I noticed that if i don't add any note in the empty row, then on the final stage to compare I actually do loose the one row from the main data,... and I rather have an error than loose the data info
I would like to add this option to check if between the main data SDPI and Cognos, there is a mismatch count, this should not happen in reality.
But if that happens, I have added the option to add (with calculation stage a comment to fill an empty row = Wcode Review Manually
Unfortunately, this doesn’t fix the primary issue, as you see the Material ID Cognos, loses the row and the match NO it is exposed for all rest of material number.
The Wcode word, is added just to ensure no error for missing row appears, but if a solution is found to resolve where the error is
Would you please be able to provide a suggestion and/or a sample that I can view and try to replicate?
MATERIAL_ID SDPI |
MATERIAL_ID Cognos |
Match? |
LCD8281101 |
LCD8281101 |
Yes |
LCD8280901 |
LCD8280901 |
Yes |
LCD8280801 |
LCD8280801 |
Yes |
LCD8280701 |
LCD8280701 |
Yes |
LCD8280695 |
LCD8280601 |
No |
LCD8280601 |
LCD8280501 |
No |
LCD8280501 |
LCD7521401 |
No |
LCD7521401 |
LCD7521301 |
No |
LCD7521301 |
LCD7521201 |
No |
LCD7521201 |
LCD7521101 |
No |
LCD7521101 |
LCD7521001 |
No |
LCD7521001 |
Wcode Review Manually |
No |
MATERIAL_ID SDPI |
Match? |
LCD8281101 |
LCD8281101 |
Yes |
LCD8280901 |
LCD8280901 |
Yes |
LCD8280801 |
LCD8280801 |
Yes |
LCD8280701 |
LCD8280701 |
Yes |
LCD8280695 |
Any comment |
No |
LCD8280601 |
LCD8280601 |
No |
LCD8280501 |
LCD8280501 |
No |
LCD7521401 |
LCD7521401 |
No |
LCD7521301 |
LCD7521301 |
No |
LCD7521201 |
LCD7521201 |
No |
LCD7521101 |
LCD7521101 |
No |
LCD7521001 |
LCD7521001 |
No |
Thank you
11-10-21 11:21 AM
