Control Room_ Environment -Sessions Display from Current date to Past. date.
KodiSrihari
Level 8
Hi All,
Processes running under selected resource are showing in sequence of 'Past date' at first and 'present running data' at last , After selecting "ALL" in "START TIME " column of Environment section.
How to set the filter so that in the Environment process should be 'Present running data' to be first and 'Past date'
should be at last.
Thanks ,
Srihari
Hi Srihari,
No need to apply any filters, you can simply click on the column header based on which you want to sort your values. To sort your values in either descending or ascending order, you just need to click on the header name as shown below:
If I again click on the header as you can see my view toggles as per the descending order according to the start time in the control room:
Website: https://devneet.github.io/
Email: devneetmohanty07@gmail.com
Hi Srihari,
KodiSrihari
Level 8
Thanks @devneetmohanty07 for the clarification.​
